97 Evinrude E50ESLEUS trim/tilt relay location??
Spank.26
The tilt will not go up or down. I hear no clicking. Trying to problem solve but cannot find the relays. Does it have any? I can’t find anything on this Motor on web.
saltchuckmatt
Couldn't find your exact model but number thirty two on the picture is it. Follow the blue and green wires to it location.
Good luck.
flyingscott
Are you missing a T in the model #? Facing the front of the boat. On the right side of the power head is a plastic cover under that is the relays. They will be with the Cdi box and regulator. Does your motor have T/N/T?
Spank.26
Good luck.
Ya I’ve seen that and didn’t help me any. Searching the model number it always directs me to a different number like that number doesn’t exist. I’m stumped
flyingscott
Is this motor new to you? I see nothing on that motor that says you have tilt and trim. There should be 3 wires with bullet connectors that should be hanging by the CDI box. Those would be for the remote switch in the lower cowling. I also do not see any relays. The T missing in your model # would denot T/N/t
Spank.26
Yes new to me and first ever boat. Previous owner says it has it and worked.
flyingscott
That motor does not have tilt and trim. The SPL models were more of a budget motor usually not having tilt and trim. It should have some kind of tilt assist.
Spank.26
Makes since! I don’t see any type of assist. It has the up/down switch on throttle and wiring. Can you tell me what this wire is for. It was just laying inside motor. Can’t find what it connects too.
saltchuckmatt
Wow, don't even have a trim N tilt (tnt) Looks like the old owner was pulling your leg or something. I take it you have a non-working switch on the control box. Anyhow....wire is what comes with the harness if you HAD a TNT! Funny.
