Kentuckylake94
Thread starter- Joined
- Aug 30, 2022
- 4
New to the forum, and running out of hair to pull. Full backstory on this engine. Original to the boat, which is a 1982 pro craft 1650v, serial of the engine, 06093360 model:115622
Engine had low compression on cylinder 3, I have touched many inboard engines, hardly any outboards. But I dug into the fun task of doing a ring rebuild on the engine. New gaskets all the way around, insured exhaust baffle plates were not warped and luckily had no bolts break off, Compression is currently 120 on every cylinder with a few cylinders within 3 psi. The engine has a new stator, cdi boxes, crank trigger, spark coming off of every plug wire, new plugs, carburetors have been rebuilt with oem kits, and yet still the engine has a sluggish miss at idle, and will run a 16 ft boat decently around 25-30 mph, studdering at any higher rpm. I took it to a shop with a guy I trust very well that tried doing a lync and sync on the carbs and timing. What he ended up telling me was that the bottom two cylinders were still misfiring even though it’s really hard to tell if you disconnect the plug wires to said cylinders. (Slight change in engine rpm) even though I have good compression. He’s stating I may have low vacuum on the bottom two cylinders. My next thoughts for diagnosing are to look into yet another compression test, and where I have the enrichment valve that is functional, take vacuum readings on each intake port. And check diaphragms on the fuel pump. Anything else you guys can think of?
