Can you access/see the tank at all? If so, take the length X the width X the height (in inches) and divide by 231. That will be you gallons. However, that assumes you have a full tank. If it is not full, you will have to remove fuel sender, stick a dowel in there and measure the "wet" part of the dowel and use that as your height in the above calculation. Or just guestimate.
