ScottinAZ
Thread starter- Joined
- Jun 25, 2009
- 865
Ok, after a bit of a hiatus waiting for exhaust parts, I have the 120 in my boat back together and tuned. running great now and no water in the oil from a burned out riser. Give it two pumps of throttle, and it starts right up, happy as a clam with this. \
now for the issue. Installed the drive today, and cannot get out of forward gear. Lower cable works great when not engaged with the drive, but with the drive installed, its stuck in drive. This is with the upper end completely loose, just manually working the cable end (have not adjusted the cable yet, as its jammed....)
I did have the lower unit off the drive, so I need to check that the intermediate shaft is properly aligned with the splines in the lower, but if this was not the case, I would not have drive, corrrect? (intermediate shaft lines up great with the mate in the transom, no issues there).
Other than something in the shifter bottoming out when the drive is installed, what could cause this?
(as a note, with the drive OFF, I have full range of motion on all cables, forward and reverse, just when I install the lower, I get bupkis)
