Scott06
- Joined
- Apr 20, 2014
- 7,567
Take the drive off and see if the shutter ,which should be at the the top of the exhaust pipe just below the down elbow, is blocking flow. If it isnt stuck in there or in drive (it went somewhere) you dont have an issue with exhaust restriction.I do not have an exhaust shutter valve on my exhaust pipe and when the issue occurred when I had it in the water the transom straps were off and I was even out in the middle of the lake when it died the only reason I'm thinking exhaust back pressure is because it runs fine on the muffs with no load obviously but idles and revs just fine as soon as you introduced water where it has the back pressure to overcome from the exhaust the engine struggles and dies in won't stay running
