Kola16
- Joined
- Jun 23, 2019
- 222
Hello all (again). I have a 5.7L Mercruiser 260 with electronic ignition and a Holley Sniper throttle body EFI. The engine recently overheated due to throwing the water pump belt and it blew the head gasket.
I have now replaced both head gaskets and all spark plugs, wires, cap, and rotor. There is no water getting into the cylinders and it is running at the correct temperature. Unfortunately now it is backfiring through the exhaust.
I checked timing and it is at 10 degrees. I also adjusted it up and down a little by turning the distributor to see if the dial on my timing light was off, but that did not change the backfire.
The AFR is reading correctly around 13.5 or so.
I then realized I might have lashed the valves wrong so I relashed the valves and did find that I lashed a few too tight. When I lashed them again, I am pretty sure I did them right.
So I am still stuck wondering why I am getting this backfire. Could I have damaged one of my flat-tappet hydraulic lifters or something? Please help. Thanks all!
