Sylva-Ranger
- Joined
- Jan 17, 2016
- 167
Mercury mid '90 75 hp 3 cylinders S/N 0G039179
When run idle , remove the top spark-plug cap (cyl no 1) and make no difference at all.
No power on the water, bad holeshot.
-Compression is 125 PSI on all the 3
- Ignition is very strong on all 3
- Clean all carburetors , drain all fuel and try whit a portable fuel tank/hose whit new fuel make no difference.
-Remove the intake and Reed valves/gaskets on the cyl no 1 is ok
- Timing/ synchro is ok
Is like the top cylinder is runing dry. the spark-plug stay dry ..........
If i unscrew the mixture screw ( richer adjustment) all the way on the no 1 cylinder , run a little bit better so is like a fuel issues ont that cylinder. The spark-plug stay dry.
I temporary invert the no 1 and no 2 carbs and no differences : The problem stay on no 1 cylinder.
The TDC mark is ok when checked whith dial gage.
When checked whit starting fluid, not evidence of air leak around gaskets.
Any ideas ?
Thank you and sorry for the bad English, not mi first language.
Any ideas ?
