Cali_Boat_Guy
- Joined
- Jun 7, 2022
- 48
Hello All,
I am a newb on this forum in need of some help. However, I have gleaned a lot of good advice reading through the threads. I purchased a 1986 Sea Ray 270 with twin 5.7 260s. I bought this boat to replace another Sea Ray that I lost in the 2020 wildfires. Enough of that, I posted a brief video of an intermittent clicking noise coming from the gimbal bearing area.
View attachment 20220904_105525 port drive noise.mp4
I removed the drive and replaced the bellows, water hose, gimbal bearing, etc. U Joints were already well greased and looked great. When I removed and inspected the gimbal bearing I could see some notches in the bow side of the gimbal bearing outer ring. Unfortunately I threw it away and do not have a photo. I thought that must be the problem and installed a new, non-grease, gimbal bearing using the proper tools. I did not replace the front (bow side) grease seal on the shaft as a buddy, experienced with boats, said don't mess with it if you don't have to. I did get my hand up there and did not detect any problems although I could have been more thorough. I installed everything, ran the engine and the clicking noise is still there.
My question is this, have you heard of a front grease seal rim causing this problem? The notches cut into bow side of gimbal bearing outer ring makes me suspect the front grease seal (or some metal debris from a blown up bearing?) might be the problem. Could a front grease seal that is out of alignment be the problem? Any words of advice would be greatly appreciated.
