Hey guys, I got a used Regal 2005 boat with a MerCruiser Chevy Vortec 4.3 v6. Im checking my t's because it is only getting 3600rpms and max 33 mphs. With a three blade 19 pitch and 4 blade 17 pitch both around 14 inches. Im pretty sure i know it can get more so I've been checking things on the boat and the forum.
Two questions about the distributor cap:
One is if in the pictures i have attached does it look like it needs to be changed?
2nd - is it connected correctly, the motor turns fine and works but according to the timings and what cylinder should be connected to what point-needle on the dist cap they would ve incorrect. Im not sure if i should move the wire plugs to how they are supposed to be. The diagram below is how it is connected as of now and the bottom part is the front of the boat and the distributor cap is how it looks from above on the motor installed exactly.
Thanks for the help
1. I drew a diagram of how
Thanks for the help
