mallardmasher
Thread starter- Joined
- Nov 17, 2007
- 39
Volvo 5.0 gxi. Fuel injection. I need some of your expert advise please.
Runs excellent through all rpm except idle. Needs a tiny bit of throttle in neutral to start engine. If I let it run for a min with throttle open and back it down to idle the engine will almost stall but catch itself and idle and a can run great all day until I turn engine off.
If no throttle is given it sarts for a second and stalls when warm or cold. I thought it was the iac so I put in new iac but didn’t resolve problem. The throttle body sounds extremely loud sucking air in at the top. When I remove spark arrester I can really hear the loud sucking of air draw in around the plenum. Is my iac out of wack ? Like the circuit is forcing iac to stay plunged closed, forcing the air to be draw in at plenum ? I’ve never remembered this loud vacuum sucking. It’s loud so I’d imagine I would have noticed this before. Any input is gratefully appreciated. Thanks
