Faztbullet
- Joined
- Mar 2, 2008
- 15,934
The 1 voltage drop occurs before the engine the is one. The drop occurs at the wires exiting PDP on the page before with only the ignition key on.You cant use EV diagnostics to trouble shoot the PDP. The 1 volt drop is normal as the relays are drawing current from system. And thats a 40amp relay.
Do you not think the 1 voltage drop across the relay could be what is causing the increased heat and eventually why the EMM shuts off?ok if TT works and the engine does not then that clears up the main power into the PDP power
seems that cooling down brings it back to life.... one method you can try is to excelerate (reduce) the cooling of suspect components. A can of cooling refrigerant from the local electronics shop will let you cool down parts (ex: fat capacitor) . work methodically and eliminate suspect parts one at a time.
if conclusive repeat the test to confirm. keep the key on START as you probe around with the coolant
common $4 keyboard spray from the Dollar store with the can help upside down may work.
check for vapour flamability
got it. Will try an IR gun this weekend. See if we can find the hot spot on the PDP or EMMyou have circuits which have voltage flowing via blocking diodes and diode do cause voltage drops so a 1volt drop does not seems exhorbitant as long as any associated connection is solid..btw diode can be affected by heat and cause an increase in voltage drop which may mess things up EMM wise. hard to say . scan the diode to see if they get HOT !!
kind of hard to pick up a component inside the EMM which suddenly opens up when to hot. the trouble case provided indicates your EMM may be at fault.
why not do an IR scan before spending $$$ to much money on a rebuild.
up to you.
This has been a long road for you guys, hope this completes it.Found two cold solders in PDP, still not fix the issue. EMM is packed up and being shipped to Chet at DFI right now.
We sure hope so too. 2022 fishing season was a season of repairs. Fingers crossed Chet gets us back in the water for the last month. At least we will have the utmost confidence in the boat.This has been a long road for you guys, hope this completes it.
Positive temperature coefficient (PTC) sensor failed and needed replacement. He also re-calibrated our EMM. Engine ran and sounded great. About 1.5 gph more efficient now at equivalent RPM.almost closed.....
Did Chet give you an idea of exactly what failed in your EMM ???
