floatfan
- Joined
- Feb 28, 2011
- 184
Thank you for the insight. I actually read the part about not revving in neutral earlier today (but after my video haha). Hoping to not need the barrel again anytime soon, but I will definitely put it deeper if I do need it again.another five or six inches of water. The kill switch closes the circuit (grounds out the coils) when the red button is "in". When it's held out by the lanyard clip, the ignition is not shorted out -- motor operates.
Don't rev in the barrel, al least for anything but a short burst or two. Check temp on top of head -- 160F is too hot and will be too hot to comfortably touch.
Btw, after seeing a YouTube video of a guy running his 1991 model, and seeing a telltale stream, I got to looking further and found a hole that I ran through with wire. Boom... telltale open. So much to learn on this little motor. Every other outboard I've ever owned that had a telltale had a water hose going to a nipple under the hood. This one is apparently just forged in.
