dieselfuelonly
Thread starter- Joined
- Mar 10, 2012
- 59
I noticed when running in a barrel, my 4SG ('88 4HP) has some water leaking out around the pin that pushes up on the tilt lock plate when the engine is in forward gear. See picture below. Can anyone help me identify which seals/gaskets I need to order?
I _think_ part #11 in this link is the grommet I'm pointing at, but I doubt that does any actual sealing, just keeping grit out - https://www.crowleymarine.com/yp/OA239366/upper-casing-bracket-4sg-1988-4hp
Should I just order the "lower unit gasket kit", #26, from here? - https://www.crowleymarine.com/yp/ZN784225/repair-kit-4sg-1988-4hp
Here's a picture, the water seems to be coming out around the grommet that surrounds the pin.
Thanks!!
Thanks!!
