captainchaos
Thread starter- Joined
- May 24, 2018
- 33
Hi, is there a difference in a marine altenator and starters vs regular ones from auto parts stores? I have a 4.3 I want replace these two on.
The reason behind this is automotive Starters/Alternators do not have the required plates to contain the sparks that are made inside these devices from exacaping which could and most likely will result in an onboard fire since the engine is confined to a small space that doesn't really vent the gas fumes like automobiles doYes. They are ignition protected. Do not use auto anything on your I/O for:
Alt
Starter
Distributor
Carb
Fuel pump
I like ARCO for alternators & starters
yes there is, and why do you want to replace them?Hi, is there a difference in a marine altenator and starters vs regular ones from auto parts stores? I have a 4.3 I want replace these two on.
Clean your battery connectionsIm not constantly pulling 13 amps. The starter has issues turning over ther engine fast enuff. Its a new battery.
I've used their stuff with good resultsAre DB altenators any good?
