Rootguitars
Thread starter- Joined
- Jan 26, 2022
- 22
How to replace point system with cd 1976 Evinrude 35
Thanks again. I very much appreciate your helpI would say it is a carburetion issue.-----Open low speed mixture 1/4 turn and test run.----And most important make sure throttle plate is synchronized and opening at the correct time.----Many years of this ignition system show the same driver coil for manual and electric start.
I do see the two coil part numbers based on the pull start and electric start. Did you buy the right one?Well I admit I don’t understand it. So…what to do to correct it?
Here is the follow up video....mystery solved but it was something else. Anyhow might show the OP how to dial in the carb....if that is the problem.Not sure if I would let that fellow work on one of my motors.----Just a lot of guessing on his part.
