178xl chapparel wiring
jclark178
Does anyone have wiring diagram for connecting a trim sensor/trim sender or can tell which wires to connect to. i removed engine for transom rebuild and did not label wires, have all wires reconnected except these two.
It would be in the factory manual drive manual.
Scott06
What engine do you have? On a mercruiser it will plug into engine harness. should be only two bullet connections back by flywheel cover
Ayuh,...... What motor,..??
What drive,..??
Chapparel builds boats, not drives,.....
