sms986
Thread starter- Joined
- Sep 18, 2017
- 334
There's a bushing that goes on the through transom barb so the larger hose doesn't squeeze down to fit on the barb itselfAm I missing a part?
The tube is oem/factoryThat little white tube is not right.
I looked but couldn't find it on parts drawings - what is your engine and drive number not sure if it will be on the gimbal housing drawing or engine...Well the hose was removed 3 years ago lol. I did a full gut and restore on the boat. Rebuilt the entire engine and gimbal assembly. I'll look around on schematics again too see if I missed something.
Item 27, list one for 5/8 and 3/4Well the hose was removed 3 years ago lol. I did a full gut and restore on the boat. Rebuilt the entire engine and gimbal assembly. I'll look around on schematics again too see if I missed something.
Might be right, then what is the correct part?Have to disagree, that bushing is what seals the water tube not the one that goes inside the hose over the tube. The hose one uses is straight no taper and that item is the trim cyl bushing
Ayuh,...... I ain't had one in my hand lately, but isn't it just 'bout an inch or so of 3/4" heater hose,..??still crawling thru all my links to find it .Its straight walled that slips inside the cooling hose
It's a bushing, looks much like one for the trim ram ends but isn't tapered.Ayuh,...... I ain't had one in my hand lately, but isn't it just 'bout an inch or so of 3/4" heater hose,..??
