Trailer Axle Wear Sleeve Alternatives?
IDFISHER
I've got some grooves and pitting on my axle where the lip of my grease seal is riding and it's chewing up my seals in no time. I found the Speedi-Sleeves that fit my trailer but they're $72/each. Does anyone have a less expensive alternative?
a replacement spindle is about $35. however you have to have appropriate fabrication equipment.
however you may want to look around. plenty of options in the $10 range
IDFISHER
Thank you. This is for a small utility trailer with a 1.5" spindle and I'm having a heck of a time finding any alternates to the speedi-sleeve part# 99149. I was able to find them for cheaper ($30) on a couple other sites but still the $10 would be nice.
What size are your bearings and seals?
Look specifically at trailer specific sites
dingbat
Read the small print on the spindle sleeves.
Bought one when I went through this process a couple years back.
The sleeve I purchased required a seal different from IE supply. Still sitting in the junk box in the garage.
99149 is the industry sleeve size
Google…. Wear seal 99149
Here is one for $23
IDFISHER
Here is one for $23
Thank you. Now, i wish they made an installation tool that was longer than an inch....sheesh. I suppose a scrap piece of pipe with the right dimensions would do the trick.
Heat up the speedy sleeve with a torch or heat gun to about 500 and slip on
dingbat
A piece of 1.5” pvc fit mine almost perfectly.
Here is a pretty ingenious hack.
You’ll need #2 permatex (non-hardening) as a sealer
IDFISHER
That's great, thank you guys!
Drcoffee
With your part number, check with rockauto.com. $23 plus shipping. And the permatex aviation sealer is what I used as well.
to install it, I found an exhaust pipe transition piece that fit the sleeve perfectly for $5 at oreilys auto parts. Plumbing pipes were either too big or too small. Use what works
