havoc_squad
- Joined
- Mar 5, 2011
- 739
Slowly making progress but going to have to wrap it up soon for the season due to weather. Wanted to field advice on the fuel tank. It’s a Moeller 36 gallon. They don’t appear to make this model anymore - it’s been almost 30 years so I’m not surprised. Dims are 48” x 29” x 8” to main top surface + ~ 1.75” for fill inlet. Looks like the Moeller 39 gallon is a bit too long for the cavity and I plan on rebuilding the boat to factory dims. Anyone know of a tank that would work without going smaller? Looks like Moeller makes some smaller units but I’d rather not give up capacity. Or, should I just put this tank back in the boat when the time comes? If so, could use advice on how to clean it. I’m pumping out the fuel through an in-line filter and there’s some sediment getting picked up, so would want to clean it before reinstalling. Thanks!
I think you got that backwards, what is all that gap at the back at the bilge.
If possible, always leave some wiggle room for the tank. Not a lot but least 1/2" or more.
On the positive side, your tank has 2x4 support grooves on the top, that will make re-installation super easy.
When you re-do the floor, always make a section that allows you to remove the floor for future removal of the tank. You'll need a few extra mounting spots installed on the stringers that are glassed in. Otherwise you'll be destroying whatever floor job to pull it if the tank fails.
