Derrick Fronckowiak
Thread starter- Joined
- Jul 15, 2015
- 112
Fellow Force Owners-I was running my 1990 Force 90 on the muffs and shut it down (nothing unusual). Later on (after a few hours) I went to start it again and the starter would engage, but would bare rotate the flywheel and then, it wouldn't rotate it at all. I had just gotten a new battery and had good voltage. So I thought the starter was dying, so pulled the plugs and tried again-no different than before I pulled the plugs. Put a socket and breaker bar on the flywheel nut and felt it binding. Could barely rotate the flywheel and had to jiggle it counter-clockwise and then clockwise just to get a little rotation. I pulled off the carbs manifold/reed plates, took my cheap Chinese endoscope and looked into each chamber for some kind of mechanical failure or breakage/blockage (looked in the cylinders as well), but couldn't find anything. Could my interior trigger flywheel magnets be coming apart and binding? Could my crankshaft had sheared between the journals or somewhere else? I'd really like to know what's causing this before I yank off the powerhead and split the case (which I may end up having to do anyway). Figured I'd ask this forum (this great storehouse of knowledge and experience), before I do something stupid(er). Anyone have any ideas or experience this before?
