sctbirdguy
Thread starter- Joined
- Jul 24, 2017
- 18
I have been fighting an overheating problem and have given up, just going to run it until melt down. However, I noticed tonight that the boat runs way better with the timing advanced a bit. It’s starts easier both cold and hot, idles much smoother, comes out of the hole without hesitation, runs up to 4800 rpm like a champ (redline). I also do not detect any pinging at WOT.
I have replaced almost everything on the engine including the timing belt and tensioner. Also, I cleaned and lapped the valves while it was apart. I triple checked all three pulleys and timing belt and everything is aligned correctly.
The factory settings are 6 degrees btdc at 850 rpm and 36 degrees at 4000 rpm with 62 degrees of dwell + - 3 degrees.
My current set up is 13 degrees btdc at 850 rpm and about 42 degrees at 4000 rpm and 61 degrees of dwell. It has the stock points.
Does anyone see a problem with this? My dad tells me a story about a mechanic that tuned by ear and hecompletely changed his cars performance and gas mileage etc. and the mechanic said sometimes the stampings are off.
Looking for opinions.
Thanks.
Thanks.
