Replacing 5.0 oil pan, gasket, bolts
mdaddy
2008 Mercruiser 5.0
Serial#: 1A322719
got a serious oil leak so needing remove engine to replacie oil pan, gasket, and bolts.
- need recommendation on where to purchase replacement parts
- oem vs after market oil pan
- oem vs. aftermarket gasket
- ordering hardware, what's up with the hardware, because the parts diagram is confusing.... bolts, studs & screws, are they both used?
- suggestions, comments, recommendations appreciated
Thanks in advance!
stresspoint
gasket go genuine , aftermarket will work if OEM is unavailable .
bolts and hardware should be fine wire brushed and painted..
have you pin pointed the exact area the leak is coming from ,its a good idea to do this before speculating .
2008 Mercruiser 5.0
Serial#: 1A322719
Thanks in advance!
GM dealer for oil pan
Felpro, Mahle, or GM for gaskets
should be able to use your existing hardware. if not, GM dealer
remember, its a GM motor that Mercruiser simply bolted their exhaust and accessories to.
Scott06
Front timing cover is plastic some have a crank trigger sensor that are one time use. If you can find GM parts they are OEM with one less (merc mark-up)
aftermarket has billet aluminum front timing covers for much much less money than the plastic one from GM
just google billet timing cover vortec
mdaddy
So if I'm understanding correctly, I can purchase an 5.0 oil pan and gasket from the GM dealer as well as hardware if need, correct? I already installed the timing cover because the original pladtic one developed a 10-12" crack in the front that was pouring oil out thinking that would solve the leak but after a test run oil was seeping out of the right side midway where oil pan meets the block thus the need to pull the engine- I have a metal A-frame engine lift so it shouldn't be to difficult.. Again, thanks friends!
tank1949
If you use in salt water, perhaps powder coated aftermarket? I'd prefer aluminum with heavy primed and painted.
ROY WILLIAMS
GM did 2007 and new the CCP parts are damaging .. plastic parts LOL !!!
mdaddy
Can I swap out the oil deflector or do I need to purchase a new one?
you mean the slinger? or the windage tray?
mdaddy
the baffle in the oil pan that's sits in front of the oil pump
Windage tray. It's in the crank case bolted to the bearing caps. No need to change.
Oil control baffles will be welded to the pan and should be in the new pan
