RubyLily121
Thread starter- Joined
- Jan 24, 2022
- 26
Hi Everyone,
We have a Four Winns 2008 SL262 with a MerCruiser model 496 MAG (H.O.) (Serial #1A350233) 425 HP. We have hand a brand new Fuel Rail and spark plugs installed (thanks to Larry at Raylar Engineering) and we have then Fuel Pump replaced with a brand new Mercury Pump and the stern drive and lots of other bits and pieces. There can’t be much more to swap out (probably could have purchased a new boat for what we have spent so far!
Anyway, we seem to have this intermittent issue that we get in the boat and have a great day out to getting in the boat the following week and can not get the engine to go past 1500rpm so we idle back to the marina… Mechanic goes out to inspect next day and running fine. This has happened a few times now and we are at a loss what could be causing it. If you can imagine it sounding like a blockage and not enough fuel getting to the engine but nothing seems to be blocked. There is no overheating, there is no beeping alerts - nothing just wont pick up speed. It was also a full tank of fuel so was not low on fuel!
Mechanic is doing its annual service next week and will also change the impeller over.
Any ideas would be greatly appreciated as it is really hard to diagnose when the mechanic can’t replicate the trouble.
Ideas welcome and thank you.
Amy
Amy
