JayBirdie88
Thread starter- Joined
- Sep 10, 2017
- 14
1988 Mercruiser 3.0, Alpha One, gen 1.
When the steering is turned to the extreme limit, left or right, a loud growling noise is produced. It only does it in the water but not on the hose. (I assume that the universal joint is not making the noise or it would do it in or out of the water)As the steering is slowly straightened out the sound is slowly reduced to nothing. When I checked the power steering fluid it was very low, (off the stick) I filled the pump to proper level but there is no change. Since the sound is associated with the steering I assume that the steering system is at fault. How can I diagnose this problem?
