Winterizing
hearts desire
I have a 1974 pacemaker sport fisher first yr it's been outside so I need to winterize.
Any info wld be grt.
350 engines,
Thanks in advance,
Change oil and filters. Drain the blocks, manifolds and hoses.
Pull the drives and do the annual PMs
Basically the info from the manual
hearts desire
Thank you for your help Scott, appreciate you!
If I run into any issue I will be back with more questions.. lol.
Thanks again,
The main thing with winterizing is to completely drain all water from the system. Make sure to mechanically clear the drain ports with a stiff wire or a screwdriver
Drain oil coolers.-----Transmission oil coolers.-----If equipped with them.
hearts desire
So how do I get antifreeze in the motor and were do I find the drain ports.
Thank you so much fellas for your help.
I'm a broke ass chic from Ontario or I wld just have someone do it for me..
Thanks again,
Drain plugs are located:
on bottom of block, just above oil pan rail.
Bottom or end of exhaust manifolds
Every hose
Once drained, it's winterized. If you want to add anti-freeze, use a funnel and add to the thermostat housing
Make sure the anti-freeze is rated for -100 and for engines
poconojoe
And if you use antifreeze...use non-toxic pink RV/boat antifreeze. Don't use toxic automotive antifreeze.
garbageguy
350 engines,
Thanks in advance,
If your boat has any water and/or wastewater systems, those need winterizing too. How will she be stored this winter vs previous winters (up here where it gets pretty cold)?
hearts desire
OK, then check the shaft gland, service the strut bearings and rudder gland, change the raw water impeller if you haven't done it recently
Hey Scott, just wanted to thank you for the help out, she is all winterized and dry dock for the winter.
Appreciate you, thanks again for the input from everyone on this forum, super helpful!
havoc_squad
Thanks again,
Lots of po' (poor) folks here in the forums who make their dollars & cents count by doing it the right way in not cutting corners from learning from the right people on this forum.
Also by not taking youtube tutorial videos as gospel when they might contain dangerous mistakes.
The only thing a DIY'r gains by doing bad practices in working on their stuff is a thinner wallet/bank account fixing their needless expensive screw ups.
A professional doing bad practices just ends up on the unemployment line a lot faster and possibly a bad reputation that they can't get rid of.
