e50tslecc evinrude
nukeone
when started motor runs wide open. checked fuel (ok)checked elect primer(ok)replaced carb gasket(ok)only way to stop engine is turn off key and open throttle wide open. engine is 1998 2cycle. any help is appreciated
Perhaps inner throttle cable is broken.-----Check flywheel key too.
Inside the cable .----It is the part that moves.----I can not see your motor.----Does throttle arm on the side of engine block move when you operate the control ?----Does timer base under the flywheel rotate ??
nukeone
not sure about timer base not familure with it. throttle arm does move
I can not see your motor , so up to you to research and provide accurate information.
Check the flywheel key.-----How did this motor run for you last season ?.-----What occurred that made it idle very fast ?----You are opening throttle to stop it ??
nukeone
only problem last year was it would not idle without dieing
saltchuckmatt
You have something very strange going on.
If you can post a video of the carbs opening and closing with the motor off.
