over heat alarm 150 hp Yamaha 4 stroke 2006
sullmate
My 24 ft. Regulator has 2 engines. Both 2006, 870 hours. All salt water use. The port engine overheat alarm goes off at 5-5600 rpm. I have replaced the impeller, thermostat and overheat sensor. No change. Is there a water pressure sensor on this engine? THE ENGINE IS NOT OVERHEATING. Runs at normal temperature. Is there a code that the computer can spit out? I don't have the tool to read codes. Could ventilation cause a low water pressure condition? If so, it is new this year. Thoughts please. Thanks
QBhoy
Hi. Is it defo an overheat alarm and not an rpm limiter alarm ?
boscoe99
There is no RPM limiter alarm on any Yamaha outboard motor. OP's motor alarms for either over temperature or low oil pressure. A steady horn.
A beep beep beep tone will indicate for the presence of water in the water separating fuel filter but only when the motor is in neutral.
sullmate
its a steady beeeeeeeep. Engine cuts back to a slower speed. Turn off engine restart no beep. No beep at all until boat is driven a while at higher rpm. Engine does not run hot.
is there a water pressure sensor. ??
sullmate
Max rpm for this engine is about 5200 rpm. not higher
sullmate
Update. The Yamaha mechanic says it is definately another sensor besides the overheat sensor that I replaced. Not sure what sensor or where it is. I will continue to update when the mechanic does the work.
99yam40
seems I remember reading about a temp sensor and another switch or something that monitors temps.
Yes let us know what you come up with
sullmate
The computer spit out a code for another sensor that has to be replaced. The mechanic said the stator and rectifier must also be replaced due to excessive corrosion. The engine (2006) has always been used in salt water in the northeast. I have not received the total bill estimate. Bummer!
sullmate
Update. total estimate w/ tax $K. Includes New Stator / pulser coil base assembly New oil pump for the port engine. New balancer assemblies for both engines. O rings, crankcase seals and new anodes. Parts,( All Yamaha) total $2418. Labor, 11 hours $1430. ($130 per hour) Work is done off season, in Connecticut. The engine was run in a test tank. Can't run in the sound until May 2023. Ouch !
saltchuckmatt
Anyone say why the overheat alarm was going off?
sullmate
replaced the water pump in both engines. No alarm. Engine suffered a salt water leak in the powerhead the sprayed the engine with salt water. This caused many electrical parts to corrode. Engine was tested in a test tank. No alarm. Can't water test till spring. COLD here in Ct.
