Rivergator
Thread starter- Joined
- May 7, 2013
- 240
I know everything drags on with me. Last spring I rebuilt the 4.3 ltr engine for my 1988 Sylvan. In August I put the engine back into the boat. Then I ran into what I thought were problems with the starter but it was something else. Now I just got done with the coupler/gimbal bearing alignment and my next step was going to be to prime the engine and make sure I have good oil pressure. I was going to proceed very carefully with that because the engine hasn't been turned since it was rebuilt. So my plan was to crank the engine for about 10 seconds at a time (I don't want to overheat the starter) by using the starter until the oil filter has filled up, circulates through the engine and oil comes squirting out of the push rods. Then the other day I saw a Youtube clip where a guy was using this slick oil pump priming tool that you install temporarely in the engine instead of the distributor, which will only drive the oil pump and therefore pump oil nicely through all the bearings all the way up to the valve rockers. Now that sounds like a solid idea to me. Does anybody have any opinions on this? Is it safe to just crank the engine until pressure builds up or should I use the oil pump priming tool. If yes, does anybody know or have a picture or number of that tool that will fit my 1988 4.3 ltr. Mercruiser engine. There are plenty of pictures and offers of the tool on ebay and other internet sellers, but they are all for car engines and I am not sure if they will fit my engine because it uses the factory thunderbolt IV ignition module and distributor. With other words, does it matter if it is a car or marine engine and does it matter what distributor is on the engine, is it all the same or should I have to watch out for any differences? I asked the seller but as one can expect they have no clue. Their answer is, if it is a 1988 4.3 ltr Chevy or GM engine it should fit, but I am not trusting their word on that
