Spark plug recommendations for 1973 evinrude 65 triumph.
McGR
Here is all you need to get the starting circuit working. The ignition does not need anything else to create spark. As long as the motor rotates sufficiently it should create spark.
TyeCope122
I am getting 12volts to the solenoid but when I try to jump the solenoid the starter won’t do anything. There is no clicking or sound when I try to jump the solenoid. It seems like the solenoid is being fed 12 volts but won’t give any voltage out even when I try and jump it
saltchuckmatt
Soloniod has 4 connections. Two big ones that I see are hooked up. Of the two smaller connections there should be one that you are jumping to and then the other one goes to ground. Check to see if you are grounded or put a jumper on it and test again.
TyeCope122
One of the small post goes to the block for ground and the other post has a wire that feeds into the big red plug. How do I correctly jump the solenoid?
saltchuckmatt
Jump the main incoming hot to the one coming from the harness. That powers the solenoid. If the soloniod does not click then its bad. Check that and report.
TyeCope122
I jumped it. Instantly the starter engaged but I’m pretty sure I have a weak starter because my starter will turn the flywheel then slow down, hesitate and then turn it again and repeat the hesitation after a spin or two.
saltchuckmatt
Could be connections. How many volts does your battery have?
And how many volts does the starter side of the solenoid have when you jump it.
To make a good test of the starter, hook up jumper cables to the hot side of the battery and starter, then the neg. Side of the battery then touch a ground somewhere. Watch for sparks.
saltchuckmatt
Hopefully you have put some oil in your cylinders and I would test this with your spark plugs out. You should keep your spark plugs hooked to your wires and ground them out otherwise you could ruin your coils.
TyeCope122
I’ve been grounding my plugs and keeping the wires connected. The engine’s definitely got compression but I think some rings might be sticking and just need to be lubricated because the engine was sitting for awhile. Also I’ve used a battery charger try directly jump the starter and he starter acted weak. The marine battery I used when jumped the solenoid was a little low. I’m hoping with a good charged battery that my starter will have enough juice to properly work.
saltchuckmatt
It's probably the battery. Don't use the charger, under-volting is hard on everything. Get a meter if you don't have one.
Have fun.
saltchuckmatt
Your starter is still struggling and your partner was playing with the connection. If you don't use all good stuff your going to ruin your starter. Also, don't get ahead of yourself, fix things before you run it.....like the water pump impeller and don't run it without water.
Here is the red plug wire diagram. Run a wire from where it's says kill through a switch and to a motor ground.
Looks like she has some life.
