With my Trim Pump almost sorted I am moving on the the ignition system...motor has (had) all kinds on automotive parts on it; carb, intake, and ignition. Distributor looks to be a normal Motorcraft with vacuum advance and the gray Ignition Control Module.
Carb will be Edelbrock 1409 as the motor has the Eldlebrock Performer that looks to be a good option for the motor.
What is the best solution to replace the distributor with? Pertronix D231801 Marine Electronic Distributor?
And this may be stupid question but does this replace the ignition control module?
As for the starter mine sounds like it is grinding rocks when I start (or as of right now just turning over) the engine. It also seems like it is staying engaged; does it only kick back if the motor starts? What should I replace it with if needed?
Anything else I should know?
Thanks!
Thanks!
