opticalhighway
Thread starter- Joined
- Jan 17, 2022
- 4
Hi there, my 5.7L Carb 2BBL starts perfectly cold. Issue is when warm after taking out on the plane and then left sitting for 10-30mins it will take 5-8secs of cranking at full WOT (in neutral) to start. So seems like a flooded engine scenarios. I have tried:-
1) two different ICMs
2) two different coils
3) carb rebuild with carefully set float to prevent boiling gas flowing in after shutdown
4) lagged the fuel lines to reduce vapour lock
One question I do have is around the choke which works as expected. Set correctly for cold start and then opens over 2-3 mins as engine warms. Does anyone have experience of the choke closing over say 30mins even though the engine is warm and then when trying to restart the air is then starved hence creating a flooded engine scenario?
Also I have seen a thread on here that sometime an older starter battery may be a problem as the hotter engine can pull more for the battery and if not great will then exhibit a poorer spark? Not sure on this one.
Any insight or comments appreciated......
