mercruiser fault codes
emourelatos
These are the error codes I am getting. Not sure what they refer to. can somebody help? I bought the rinda tech software package thinking the codes were in their system but no such luck. thanks in advance.
PITOT CKT LO Code is active
FUEL LVL CKT HI Code is active
STEER CKT LO Code is active
SEA TMP CKT HI Code is active
FUEL LVL2 CKT H Code is active
Fun Times
Is this on an Outboard or Mercruiser stern drive type boat?
All those are usually normal codes you'll see on engine applications that don't typically utilize these sensors... They're disconnected so they create a code that will usually only be read when a scan tool is connected.... If the sensors were being used and something went wrong, then you'd most likely get a different type of notification depending on what system is being utilized to monitor the engine warning system such as a warning horn or icon in a gauge sometimes.
These are usually considered "ignored" unless they're actually plugged in and being used which sometimes depends on what boat model/ manufacturer/dealer/new owner and $ equipment added to the build of the boat.
QBhoy
Hi. These are standard inherent errors shown for sensors that aren’t fitted or applicable. These show up on vessel view on my mercruiser mpi. Saying that, the sea water temp might not normally be there. I’ll post a picture of the ones on mine below. They are blocked.
Sw isn’t there. Might need to look into that.
