seahorse197220
Thread starter- Joined
- Feb 26, 2012
- 73
Nice! Thank you!1996-2000 5.7 liter
10243880...350...95-00...2 or 4...Vortec truck, Gen.I crate motors and "ZZ4", roller cam, one piece rear seal
Thank you!Definitely a MPI model engine that was connected to a stern drive. Probably in the 430 HP range. Looks like the model of engine that was in the Donzi I had.
I will look for this after work. Thank you.Is there a aluminum type tag just above the engine starter?
Clean the casing of the EFI's "ECM" as there should be some stickers on it that should tell a bit more about the engine designation model it would have been/fit which looks to be an Alpha stern drive and possibly engine year which that model should have started in either late 2002 /early 03.
Agreed - 300 hp and looks like it is for an alpha not a bravo as there is no belt driven seawater pumpMpi 350 is where my money is. 2002 onwards with the quick drain system shown there.
I didn't see one. Thank you.I will look for this after work. Thank you.
Thank youMpi 350 is where my money is. 2002 onwards with the quick drain system shown there.
was it running? I never see a heat exchanger that small.Thank you!
fine motor but why was moved from boat or maybe removed from truck in lieu of putting into boat. Run compression and oil checks to be sure. Keep in mind if your boat is carbureted, it is more laborious installing an EFINice! Thank you!
