gpeter1492
Thread starter- Joined
- Dec 2, 2022
- 5
Rain water collects in my mid bilge but does not drain even when bilge pumps operate.
during a good rainstorm I can get 12 to 18 inches in this midship bilge. It will slowly drain over 10 days. Is there a midship bilge somewhere on a Crownline E29?There will always be a bit of leftover water in there. Or does it not drain at all?
I have just aquired the boat and getting to know it. The midship bilge is designed to let rainwater in as it has drain holes under the deck cover. My problem is the water stays in the bilge. There must be a defective bilge pump that I have not located yet.Not sure if there is a pump there, if not there should be. If it’s draining slowly over time, there must be a pump someplace. I really think you should have a qualified tech look at what you have going on, for one, find out where the water is getting in. Seems you should get to know your boat a little better.
I will try thatcheck the drains or limber holes for blockages
