- Joined
- Mar 8, 2009
- 44,078
Never thought head bolts would be such an issue.
Mistake 1 was to use a 454 as the baseline for the head, wrong. Find a ARP kit 3607 which comes with 3 different lengths and 8 are 5 inches which are to long.
Original bolts removed from head were 24 each at 4.187 and 8 at 2.187, with speck listing is 4.125 and 2.125 respectively.
New bolts are 4.060 and 2.060 which are same as required for 502. The 502 has some blind holes and the 454 does not. Most on OSO use 3601 which has 3 different lengths of bolts but only 4 bolts are longer then others which are used in the lower inside corners of the head. Have questions out trying to find out what are the lengths of the actual bolts
The 454 MPI is a different animal
