maineiac5586
- Joined
- Feb 14, 2009
- 828
I'm working on a 1986 70 hp 3 cylinder. Issue is trim won't work when the 2 wire connector is connected (the connector from the relays to the trim motor. I just get clicks from the relay. If I disconnect the plug I can get trim to work when applying voltage directly to the trim motor wires. I have 12 v at the 2 wire connector from the relays when activating trim switch (12 v in up and down positions but only if not connected to the trim motor wires. I checked the voltage at the wires when the connector was plugged in but only getting 8 v or so (on the wires coming out of connector leading to trim motor.) Thinking I was having a bad connection I cut the connector off and wired the trim motor directly to the blue and green wires coming from the relays but the issue still presented itself (relays just buzzing and only 8v or so). My battery is fully charged and cranks the engine fine. I tried 2 new relays but still no dice. Hopefully someone can help me
