markhodges78
- Joined
- Aug 4, 2016
- 435
I had an cracked head issue with My 1993 3.0 so I swopped the engine with A spare 88 3.0 that I had. I swapped over the manifold , carburetor, and distributor from the 93 engine. The 88 engine had points the 93 has Ignition Module, any way I set the timing per my 93 engine which would be 1° BTDC ( serial number 0F267594 ) but then when I checked it out of base timing the advance was 16° BTDC.
Per the manual there are 3 different base timing settings for this engine what determines what the settings are.
I did replace the distributor a few years back with a used distributor due to an issue with the pickup coil. should I be setting the timing at 1 of the other 2 settings 1° ATDC or 2° ATDC ?
