Water not coming from pee tube.
jerryjerry05
2003 Yam 200TXRB About 300 hrs.
Motor starts and runs fine.
No water from pee tube, even if taken loose at the rectifier.
Tried weed eater string up in the rectifier and nothing.
Should I try taking the rectifier apart?
Would this make the cylinders overheat? Temp was high on the center cyl. 190d. 150-60 on the others.
THANKS!!
jerryjerry05
Also the owner said the impeller was replaced last year.
dingbat
That motor is front and center in the era of dry exhaust corrosion.
Have you had the mid-section off to inspect?
jerryjerry05
Dingbat, no.
This is the first time anything has been a problem.
I've heard about that problem. School me!!! How do you test for that?
What does the corrosion do and how does it affect the performance?
As always, THANKS!!
jerryjerry05
Dingbat: Thanks,
The post was 10+ years old and dropped the pics.
But Google helped find them.
jerryjerry05
No Firefox.
I tried downloading FF and just ended up having trouble???
dingbat
No Firefox.
What kind of problems?
What OS and browser are you running?
All Windows updates been installed?
Lots of info on Chrome removing pictures for security reasons
jerryjerry05
Pulled the reg and found sand and gunk blocking the system.
Tried to flush and had good results after cleaning.
My guess, two things: not flushing long enough or not flushing often enough.
Thanks everyone for the help.
I'm done with this post.
