PosessionSound26PC
- Joined
- Sep 21, 2020
- 76
Let me first thank @San_Diego_SeaRay for the help he provided on my previous issue with my 1989 Formula 26PC - starting issues due to bad/corroded starters and slave solenoids. Previous post here:
forums.iboats.com
I finally got the boat on the water late last year for a test run and ran into two more problems. After letting the motors warm up at dock (all gauges seemed fine), we headed out in the no-wake zone while I kept an eye on the gauges. Maybe 10 minutes later, I noticed the Port motor starting to overheat and I shut it off after a while and limped back to the dock on Starboard. I can troubleshoot that on my own this winter (thermostat or failed impeller?) but while trying to winterize the motors, I ran into the following starting issue:
(I have brand new batteries and starters for both motors, and ignition wires and starter slave solenoid for starboard only)
Started starboard motor, let it warm up. It started/turned-over strong. Sounded good. I remembered I had forgotten to grab the fogging oil and shut off the motor so I could go get it. Came back and for the life of me, I could not start that motor again. It turned over strongly - no sign of battery or starter motor weakness, just no ignition...
Decided to move on to Port motor - I thought maybe the batteries HAD weakened so maybe having Port turning would let me start Starboard. Successfully started Port - again, it turned over strongly and there was no sign of weak battery.
Now here's where it gets weird for me: while Port was running, I attempted to start Starboard again. As soon as I turned the key, Port immediately died. I haven't had a chance to look at the wiring schematic yet... I know there is a 50A circuit breaker but since the Starboard starter works, I assume that isn't the problem... There's a 20A fuse somewhere at the key but again, the starter turns over so assume that isn't it... Coil?? What would engage with the key to ground out the Port motor while running? I should mention that this was repeatable - attempting to start Starboard kills Port every time.
Starting Issue After Unrelated Mech Repairs
I have a 1989 Formula 26PC w/ twin Merc 4.3 and Alpha I's. Long story short: starboard engine froze up, shop where I store boat said new motor needed, buddies and I decided to do it ourselves w/ rebuilt motor so prepped by tearing stuff off (exhaust, electrical, etc), decided to look for the...
