So if the skeg has damage you have to replace the whole assembly? That does seem right.There is none because the skeg is matched to the upper part of the gearcase. Yeah, some people have succeeded in mismatching them and gotten away with it, but that isn't supposed to happen.
There are lots of good gearcases that would fit.----These motors were basically the same for 20 years.-----You local ---aomci---- member might have 1 or more.
I saw that earlier. If you click on it, it is sold out.Weird really.
I found this but not sure where it even is.
Johnson Evinrude 18hp Outboard FD-12 1958 Gear Case 382832 377117 Lower Unit
Item Details This was off an 1958 Johnson 18hp Sea Horse (Model Number FD-12, (Serial Number 1707675) Gear Case Gearcase Lower Unit Skeg Housing Drive: 377117, 0377117, 382832, 0382832 Good Working Condition. Been Pressure Tested and Filled with new Gear Oil. Some Corrosion and Needs...www.nlamarine.com
Consider how it was made and it will make sense. The upper and skeg parts were bolted together, then the inner cavities were machined. So, in theory, no other two parts will match exactly. Some other parts made this way are the cylinder & crankcase and connecting rods.So if the skeg has damage you have to replace the whole assembly? That does seem right.
Somehow I missed the big red sign! Sheesh.I saw that earlier. If you click on it, it is sold out.
No big deal, I appreciate you trying to help.Somehow I missed the big red sign! Sheesh.
I never dreamed they were made that way. Hopefully this one will work since I can't get a replacement.Consider how it was made and it will make sense. The upper and skeg parts were bolted together, then the inner cavities were machined. So, in theory, no other two parts will match exactly. Some other parts made this way are the cylinder & crankcase and connecting rods.
What's wrong with yours? Post a picture perhaps.I never dreamed they were made that way. Hopefully this one will work since I can't get a replacement.
