I recently changed took apart the FSM to changed the low pressure fuel pump. Put a new seal kit in it. Inspected/cleaned all components in it. Did not change the pressure regulator. This model FSM does not have a float in it. Re assembled and tried to start the motor. It cranks but will not fire off. Fuel is coming out the exhaust so it’s getting fuel. Have not check fuel rail pressure yet. The attachment is the FSM I have installed.before the FSM was disassembled the engine would run so it’s getting fire plus I checked the plug wires, changed the spark plugs and ohmed out the ignition solinoid. I cleaned the fuel injectors and bench tested each of them. I believe the fuel pressure should be 38 to 40 PSI. Once I confirm that it is good I am clueless how to move forward. Questions: can it be getting too much gas? If so pressure regulator in the FSM? Can the injectors be staying open?
