icuOklaCity
Thread starter- Joined
- Oct 27, 2016
- 7
Went to unload the boat last weekend and notice no water pressure or any water coming out of pee-hole.. So I replaced the impellor this weekend.. (Old impeller didn't really look to bad) After getting lower unit back on I put muffs on and fired motor up. still nothing from pee hole. Turn off motor and hooked up hose to motor flush nipple to flush out any blockage. I got water circulating and coming out pee hole when flushing. Put muffs back on and again no water coming from pee hole...
Any ideal on what is going on..??? I dropped the lower unit back off to make sure I didn't miss getting the water tube lined up. Not sure if I'm not getting enough water pressure/flow from the muffs...?
