rickasbury
Thread starter- Joined
- Jul 13, 2011
- 881
I am on a quest to have my trim work correctly. I worked through a helm switch issue, trim selonoid issue and now down to the trim sender and limit switch, bravo lll. Both sendors I replaced via another issue and the sender nver worked...
Found a good test for the system which starts with the sensor and an ohm test which I did and it failed. So, also in the instructions, which puzzled me at the time, was to remove the sendor and turn it by hand. It further said if it now passes, grease the hinge pin...I could not stretch that far- I did mark the hinge pin and raise the drive and the dam thing is turning with it! How can that be? 145 lbs of torque on it, not corroded..
