CLi87
- Joined
- Sep 21, 2018
- 219
I did a search and found some similar threads but no real answer to my issue. I have a 2004 Mercruiser 3.0 with unknown history, supposedly the boat was winterized but I'm not sure if it was done properly. When I got the boat, the oil looked good and compression test was good, on the first trip out I checked the engine bay after 10 minutes of running it at about 3k RPM's and there was brown oil all over the top of the engine, it was coming out of the breather hose that connects to the carburetor. I limped back slowly to the nearest dock and noticed spurts of water was coming out of the breather hose and there is definitely oil mixing with water. After I got the boat back I did another compression test and it still tests out good, all cylinders were about 160 psi. There was no water on the spark plugs either. At this point I'm thinking cracked block or cracked cylinder head, is there anything else that could cause these issues? I'm waiting for an adapter to arrive so I can pressure test the cooling system and see if I hear anything but meanwhile was looking to see if anyone here may have any more insight?
