Alpha 1 gen 1 compatibility
shughes12
I have a cracked lower unit alpha 1 gen 1 year is 1987.
I have found a 77 MR 1
Can I use the lower unit on my leg? Picture is of the leg I'm looking to purchase Screenshot_20230306_094758_Facebook.jpg
stresspoint
i believe you can use the LU from a gen 1 on a gen 2.
i was advised i could ,as i had a spare gen 1 LU and was not sure whether the one that come with the boat ( gen 2 outdrive) was in usable condition.as it was my gen 2 LU was Ok condition so i never got to prove compatibility.
Scott06
You cannot swap gen one and gen two lowers
the MC1 drive pictured would bolt in place of a gen 1 drive if they had the same upper ratio.
I believe the lower would swap on the gen one upper. only concern might be if it has the preload pin on dive shaft not sure if that causes and issue using in later non preload pin drives.
Maybe @Bondo or @kenny nunez can confirm
Scott06
The new leg I got has the pre loaded pin but the one I'm replacing doesn't, is that an issue? I looked on that thread and couldn't find an answer
click on the link to thread posted above in this thread ...
Mrzoooom
These gentlemen helped me along while I was in same situation...see the following;
Lost gearage?
Mrzoooom
Lost gearage?
The above is a bit confusing as I meant I swapped out my gen 2 with a good gen1 successfully!
