Crack found in the block
stresspoint
i have one up the yard cracked around the same area , we don't get freezing temps here either so i would be keen to know what conditions your engine was used in.
that being said the crack in my block was not as apparent as yours.
BTW , any patch , weld or repair to that block is never going to work out well, find a used engine from a junk yard and swap all your stuff over you will get out of it for less than a grand in gaskets , freeze plugs and any other new bits you need
flashback
Well don't beat yourself up too bad, you're probably not the only one..
I wouldn't trust any of the parts left that have coolant passages. Find an old truck engine and convert it to marine...
Karl1972la
The thing is this boat is our glue basically to our family
Many years of family fun, now I ether break it all down and replace with family (bonding moment) or buy a newer bigger boat one day
nola mike
No it was the original engine. Looked on google and all replacement engines cost that much to replace. Paid 6500 for the whole boat back 6 years ago. The motor replacement is more than the complete boat
You can do it for much cheaper depending on level of "newness" that you're after. I pulled a long block from a junk yard for $185. An '02 means you can get a late model engine and use all of your existing accessories.
Karl1972la
Here is the boat
Great…5 grand to 10 grand and I paid 6500 6 years ago for the whole thing
BS
a reman'd motor is $2800. a good running 4.3 from the local pull-your-part salvage yard is $300. add marine gaskets, core plugs, new water pump and new manifolds and thats only $1000
JASinIL2006
Can your brother help you pull this an replace the block? Lots of cheaper options than buying a whole new engine, and if the boat is well loved by the fam, well worth the work and expense...
Karl1972la
I’m not engine builder
Yes YouTube videos are a great help
Think I’m gonna cry for a while
dave8311
You're not building an engine, just bolting some parts onto it.
Not that hard, really.
Depending on your yard/garage/tree situation the hardest part maybe getting the old one out and the new one in.
flashback
I suppose you managed to disassemble the broken motor so with some care you could probably dress a new one... best of luck..
tpenfield
Nice going . . . new block would be good for you. No good way to tell about internal cracks. . . .
Was this your doing or did you acquire the boat/engine in this condition?
airshot
Find a replacement boat....or just get a whole new motor !! Some years back, I had a 3.0 that I thought might have an issue. Checked on remans, long blocks etc. Actually could buy a brand new engine from Mercury with everything, ready to run so to speak, for only a couple hundred over a reman engine !!!!
Scott06
I live in Louisiana with usually mild winters and have never winterized the boat
In hind sight especially after taking all the parts off I didn’t realize how much water was still captive. It of course is my fault
Ok easy enough to drain going forward
That’s why I suggested getting a truck 4.3 and marinizing it. Places like Michigan motorz and rapido marine sell reman engines If the rest of the boat is worth investing in
In 2015 I bought a clean 21 ft bowrider for $3k had 37 hrs on it was in perfect shape but had a known cracked 4.3. cracked in same
Places yours did just not as severe. Spent $5 k on a new 5.0 partial engine package. Basically spent $10 k by the time I did the engine and put new surge brakes and tires on trailer, boat was about $18-20 k value so made sense.
If you are handy it’s not hard to do the work
FWIW, there are busted blocks in Florida, Texas, Georgia, and Louisiana this winter
Karl1972la
both truck motors and boat motors came from the tonawanda ny engine plant
both truck motors and boat motors were built with the same block, heads, cranks, rods, pistons, valves, etc.
boat motors get brass or stainless core plugs
boat motors get a marine cam (no overlap)
boat motors get a marine water pump with a brass impeller
boat motors sometimes get a different oil pan
Boat motors are then shipped to the marinizer that adds the marine induction system, front engine accessories, rotating electrics, ignition, and exhaust
Just found a 4.3 truck engine 400.00 and will get it home Tuesday 3/28
Karl1972la
It just froze a couple of days and I didn’t realize how much water was still captive in the motor.
