twocyclemania
Thread starter- Joined
- Aug 10, 2010
- 505
Thanks!see on the recoil post... btw not hard to fix![]()
Thanks everyone! It's up and running and cooling nicely now. At first I though it must be some other problem as it was still overheating. I did notice that (in the barrel) a lot of water that stayed cold was coming out the leg holes even though the block/head were getting extremely hot. I thought I had managed to get the water pipe into the pump when I put the power head on but obviously not. Dropped the lower unit and sure enough I missed. I should have dropped the lower unit from the beginning.
Seems that the little hard buildup (brown - probably dried mud) that blocked the exhaust cooling chamber exit hole (on top) was the problem all along. Running great now! (I'm going to start a new thread about the recoil - another story). thanks!
Thanks; starting to think I was going crazy. I'll run in on the lake and let you know. thanks again!running a 4hp in barrel creates lots of air bubles sucked up the water pump which prevents cooling the ph.
try the engine on the water
