non-VRO fuel pump swap for Johnson 115 v4 Ocean Runner
UtubeMechanic
Hi all, I have a 1991 Scout Sportfish 172 center console with a Johnson 115 v4 two stroke Ocean Runner outboard that I've been fixing up. I purchased it with the VRO already deleted, but still utilizing the OEM fuel pump. Yesterday I replaced all of the old hoses and when I was reinstalling the pump, I broke the top nozzle off as seen in the photo. Seeing as how the oil and gas are pre-mixed, can I use one of those simple $30 non-VRO fuel pumps? Every video I've seen on how to swap has the pump located on the port side of the motor, not in the under centered mounting location, but I'm sure I could figure a bracket out. The only problem is I don't really know what each hoses' purpose was when I pulled them, just where they connected back to the OEM pump. Is the swap to the simple non-VRO pump simple or is there some major thing I'm overlooking? And would I need a 2 or 3 nozzle one? TIA! fuel pump broken.pngfuel pump spot.pngnonVRO fuel pump.png
I would look for a used housing to repair your VRO.----Should be lots around.----Model # of your motor ?----Your location ?
UtubeMechanic
Thank you. I ordered one that fits and looks similar off Amazon but have read they should not be relied on. The bottom nipple is also straight up and down and when the hose is connected, it's bent pretty badly. The OEM one has an elbow nipple that's even offset from center which fits way better. As for the engine, I have no idea - the serial number plate is gone and the bolt stamp is "G3941125" which apparently doesn't exist. I know the original Scout Sportfish 172 would've come with a 90hp so this was an upgrade and I think I've narrowed the year make to 1995 - 1997. I'm in Savannah GA.
UtubeMechanic
I also don't want to repair the VRO - I like mixing the gas with the oil and it's one less thing to think about. I just don't know what the guy did before me to "delete the VRO system" and which hoses are still in use vs. which are essentially useless now. I made this rough diagram to help me match the hoses back, but I'm not certain which ones do what. I made the 3 nipples red, green and blue to stand out. Not sure if it's helpful or not.
Go with that pump in the picture.----Fairly easy to figure out the hoses.----Fuel in is the black nipple.----Fuel out is the brass nipple to the left.
Faztbullet
I have not had any of my customers that used that double stack pump with success
havoc_squad
For aftermarket mixed fuel only pumps, would it be safer to direct them to maxrules website instead of an E-Bay posting since the aftermarket fuel pump offerings are rather small and usually counterfeit garbage?
I could see if it was the OEM fuel pump being asked about in not competing against iBoats online store.
Too many of those terribly made Chinese made ones with abysmal quality. Not everything from China is bad quality but the issue is there's no real incentive for distinguishing certain makers versus others there.
flyingscott
That allows you to use the existing fuel fittings. Why do you think you need the double pump.
UtubeMechanic
OMG thank you for recommending MaxRules, now I can throw away my crappy drawing diagram! I feel like I'm at least starting to not operate blindly
On the " double stack " the PRESSURE chambers are fed by one port.------On a motor like that I would install a fuel pump off a 66 model 100 HP.----Can pump plenty of fuel.
UtubeMechanic
Thanks all, I ordered the part from MaxRules (MarineTech) and will let you all know how it goes
