thomascrown
- Joined
- Apr 17, 2022
- 24
New Impeller, water pocket is good. New Thermostat 140 degree, installed correctly. New temp gauge, did not install the new temp switch.
Hit the fresh water lake while making my way out to the lake the boat temp was about 180, over about 30 minutes it started to creep up to 230. Give it some RPM, it quickly drops back to 180. Took it for a fast cruise, it dropped back to 160 and ran fine. Back to the port, at no wake speeds temp stays around 180-200, idle or trolling speed 220-230.
So my plan is to:
Check water flow by disconnecting raw water line to thermostat and check water flow. If not good, plan to check oil cooler for blockage. If no blockage, I plan to pull the hose at the transom and look for blockage. If I am good there. I am not sure where to go. Check my balls to make sure they aren't loose.
I bought a new engine water Circulation pump as a last ditch effort. It seems like these don't fail, and I don't know the symptoms they show when the fail. I would guess overheat at high speed, hate to mess with it if I don't need to.
Can I blow out the oil cooler with Air? Or just back flush it? It doesn't look like it will be easy to get to, to completely remove it.
Can I flush the engine/ run the engine with a hose thru the thermostat raw water intake? What would this prove, if anything.
Where else would I want to look for blockages, as I imagine the oil cooler is going to catch anything of size that would cause problems.
This doesn't seem like riser/ exhaust issue, but water issue. So I haven't pulled them, they look good, no rust ect.
I did not replace the water pump base when I did the impeller, not sure if that would cause the issue I am having.
Not sure what else, or where else to look.
So my plan is to:
