redtyler3000d
Thread starter- Joined
- Apr 6, 2023
- 6
I have an 87 150 evinrude compression shows
2-90 psi 4-85psi 6-81psi
1-85psi 3-85psi 5-85psi
I rebuilt carbs and confirmed good spark on all cylinders and got timing set to spec (can’t remember ° set to but did research prior) motor runs like a new motor without load or in neutral but once in gear with some weight in front of it anything above idle just has no power most of the times it will run fine just has no power occasionally it will buck when bogging down. I just rebuilt carbs but used a cheap kit and they’re still leaking I know this has something to do with my problems but I think there’s more to it pumping the bulb or pushing choke does nothing. Any tips would be appreciated but main concern is compression is this motor runnable or does it need a rebuild/ I need to repower
thank you! First post hoping I got in the right thread apologies if not.
